| Message |
i just purchased this amp. the connectors for the speaker wires (output) just appear to be screw type, where i'd strip off a bit of the wire, put it in a hole, then tighten a screw. in the picture below, each brass connector has a screw on the top that is visible here, and on the bottom in a similar orientation is a hole for the wire. i wanted to find out though, if there is any better way to use these connectors. specifically, i was wondering if maybe there was some type of ring connector that's made to be used with a screw type connector like this.
thanks. andrew davidoff
